AutoCAD Civil 3D General Discussion
Distinguished Contributor
wings1080
Message 1 of 13 (215 Views)
Accepted Solution
Areas of Elevation Bands
215 Views, 12 Replies
01-22-2014 11:23 AM
hi there!
i have a bathymetry map that I need the total square footage areas for the following depth bands
shallowest to 39
39-42
42-45
45 to deepest
any ideas?  is there an easy way?
see the attached image, i would need a sum total of the square footage for the CYAN and the GREEN each
THANKS!
*Expert Elite*
wfberry
Message 2 of 13 (171 Views)
Re: Areas of Elevation Bands
01-23-2014 06:03 AM in reply to: wings1080
Perhaps Murph will sneak in here shortly, but it appears to me that you could use Raster Design to select pixel colors.  Believe me, this is as far as I can go.
Bill
ericvallejo7526
Message 3 of 13 (168 Views)
01-23-2014 06:13 AM in reply to: wings1080
You can get an area by adding/creating a legend table: elevation.  You can find the legend table either in the ribbon tab if you have the surface selected or under the surface menu "Add Legend Table..."
Depending on how your table style is setup, you can add a field for "Surface Range 2D Area".  Hope this helps!
Eric Vallejo, LSI
Missman, Inc.
Civil 3D 2014, SP2
Windows 7 Professional, 64-bit
wings1080
Message 4 of 13 (163 Views)
01-23-2014 06:17 AM in reply to: wfberry
wow, can you say a little more about the raster/pixel approach?
wings1080
Message 5 of 13 (161 Views)
01-23-2014 06:17 AM in reply to: ericvallejo7526
this is exactly what i was hoping for!!!
would it be possible for you to please describe the steps in doing this?
ericvallejo7526
Message 6 of 13 (154 Views)
01-23-2014 06:40 AM in reply to: wings1080
Assuming your surface is created and ranges are set, you will next need to set up the table style:
  1. Go to "Settings" tab in your Toolspace
  2. Under Surface --> Table Styles -->Elevation  there should be a table style (assuming these styles were never set up, it will most likely be "Standard")
  3. Right Click and "Edit.." OR "Copy..." the style
  4. In the "Table Style" dialog box, go to the "Data Properties" tab
  5. To create a field for your specific need, click on the "+" (plus sign) to add a new field
  6. You may have to scroll to the right to see the blank field, click in the emtpy "Column Value" box
  7. Go to the "Properties" tab, then under "Properties:" select "Surface Range 2D Area" and edit any desired "Values"
  8. Click the Arrow "-->" to input the field into the Column, then Click OK
This will populate the "Column Value". You will just need to add a "Header", then edit your table based on how detailed you want to get.
Eric Vallejo, LSI
Missman, Inc.
Civil 3D 2014, SP2
wings1080
Message 7 of 13 (147 Views)
01-23-2014 08:35 AM in reply to: ericvallejo7526
ugh, i am using civil 3d 2012, is it possible we have different dialog boxes?  see attached screen shot ... i don't see a "properties" tab as you describe in step 7
wings1080
Message 8 of 13 (139 Views)
01-23-2014 08:46 AM in reply to: wings1080
also, ranges aren't set, how do i do this please?
ericvallejo7526
Message 9 of 13 (133 Views)
01-23-2014 08:53 AM in reply to: wings1080
In step 6. you will need to click in the empty Column Value box; in there you will see the properties tab.
You will set your elevation ranges, color etc. via the surface properties, under the Analysis tab.
Eric Vallejo, LSI
Missman, Inc.
Civil 3D 2014, SP2
wings1080
Message 10 of 13 (132 Views)
01-23-2014 08:56 AM in reply to: wings1080
i think i may have figured it out, can someone please tell me how to interpret these numbers?  (see attached)
for speaking purposes, number 5 which is 43' to 44', what is the 12,164.09 area????
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
