AutoCAD Civil 3D General
Message 11 of 13 (39 Views)
Re: Areas of Elevation Bands
01-23-2014 09:10 AM in reply to: wings1080
The number in the most lefterly column (the number 5), is simply an identifier for a specific range.
If you chose to define the column properties as "Surface Range 2D Area", the column with "12,164.09" is the total surface area of the given range.  This result is also dependant on what "values" (Units, Precision, etc.)  you set in the Column "properties" (step 6-7).
Eric Vallejo, LSI
Missman, Inc.
Civil 3D 2014, SP1
Windows 7 Professional, 64-bit
Valued Contributor
Message 12 of 13 (34 Views)
01-23-2014 09:12 AM in reply to: wings1080
hmm are these areas in square feet or acres?  where can i find that out please?
Valued Contributor
Message 13 of 13 (17 Views)
01-24-2014 06:12 AM in reply to: wings1080
thanks Eric
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
