Civil 3D Forum
Areas of Elevation Bands
12 REPLIES 12
Message 1 of 13
1701 Views, 12 Replies
hi there!
i have a bathymetry map that I need the total square footage areas for the following depth bands
shallowest to 39
39-42
42-45
45 to deepest
any ideas?  is there an easy way?
see the attached image, i would need a sum total of the square footage for the CYAN and the GREEN each
THANKS!
12 REPLIES 12
Message 2 of 13
wfberry
Perhaps Murph will sneak in here shortly, but it appears to me that you could use Raster Design to select pixel colors.  Believe me, this is as far as I can go.
Bill
Message 3 of 13
You can get an area by adding/creating a legend table: elevation.  You can find the legend table either in the ribbon tab if you have the surface selected or under the surface menu "Add Legend Table..."
Depending on how your table style is setup, you can add a field for "Surface Range 2D Area".  Hope this helps!
Message 4 of 13
in reply to: wfberry
wow, can you say a little more about the raster/pixel approach?
Message 5 of 13
this is exactly what i was hoping for!!!
would it be possible for you to please describe the steps in doing this?
Message 6 of 13
Assuming your surface is created and ranges are set, you will next need to set up the table style:
  1. Go to "Settings" tab in your Toolspace
  2. Under Surface --> Table Styles -->Elevation  there should be a table style (assuming these styles were never set up, it will most likely be "Standard")
  3. Right Click and "Edit.." OR "Copy..." the style
  4. In the "Table Style" dialog box, go to the "Data Properties" tab
  5. To create a field for your specific need, click on the "+" (plus sign) to add a new field
  6. You may have to scroll to the right to see the blank field, click in the emtpy "Column Value" box
  7. Go to the "Properties" tab, then under "Properties:" select "Surface Range 2D Area" and edit any desired "Values"
  8. Click the Arrow "-->" to input the field into the Column, then Click OK
This will populate the "Column Value". You will just need to add a "Header", then edit your table based on how detailed you want to get.
Message 7 of 13
ugh, i am using civil 3d 2012, is it possible we have different dialog boxes?  see attached screen shot ... i don't see a "properties" tab as you describe in step 7
Message 8 of 13
also, ranges aren't set, how do i do this please?
Message 9 of 13
In step 6. you will need to click in the empty Column Value box; in there you will see the properties tab.
You will set your elevation ranges, color etc. via the surface properties, under the Analysis tab.
Message 10 of 13
i think i may have figured it out, can someone please tell me how to interpret these numbers?  (see attached)
for speaking purposes, number 5 which is 43' to 44', what is the 12,164.09 area????
Message 11 of 13
The number in the most lefterly column (the number 5), is simply an identifier for a specific range.
If you chose to define the column properties as "Surface Range 2D Area", the column with "12,164.09" is the total surface area of the given range.  This result is also dependant on what "values" (Units, Precision, etc.)  you set in the Column "properties" (step 6-7).
Message 12 of 13
hmm are these areas in square feet or acres?  where can i find that out please?
Message 13 of 13
thanks Eric
Rail Community
