Civil 3D Forum
Arc Labeling
8 REPLIES 8
Message 1 of 9
thendryx
702 Views, 8 Replies
Arc Labeling
Just started a drawing in C3D 2013 using an existing template.  If I draw an arc using the "Angle"  rather than length or radius, entering the angle as 11.1601, then label the arc, the delta angle is converted to hms or 11.0936 .  The template and labeling style are ones we've used for several releases.  I've compared the feature settings, units and the curve labeling command and can not find where this is being changed.  Thanks in advance for any suggestions.
TLH
8 REPLIES 8
Message 2 of 9
wfberry
in reply to: thendryx
hms =  hours, minutes, seconds.
I assume you did not mean that.    So try the AECDWGSETUP command to change your template.
Bill
Message 3 of 9
thendryx
Bill, thanks for responding.  You are correct, I didn't mean hms, was caught up in the moment and put on paper how my HP-41 is labeled.  I checked to see how the AECDWGSETUP was set in my C3D 2012.  It was set to Degree/Minutes/Seconds, whereas the 2013 was set to Decimal Degrees.  I made the switch to D/M/S and restarted the AutoCad, however the program is still taking the delta angle and treating it as a decimal degree and converting it to D/M/S. I then created a new template utilizing D/M/S and started a new drawing using the new template, but I am still getting the same results.
Message 4 of 9
wfberry
IF you would attach a small file if would certainly clear up a few things.  If you want C3D to label in Decimal degrees, just change your label style using the label composer.
Not sure what you are referring to.
Bill
Message 5 of 9
thendryx
Bill, hopefully this simple drawing will clear up the problem I'm encountering.
TLH
Message 6 of 9
wfberry
T:
Here is the file sent back.  I am showing your angle was entered as 11 Degrees 9 Minutes 36 Seconds.  The same as your label.
Perhaps I am looking at the wrong thing.
Bill
Message 7 of 9
thendryx
Thanks Bill, I believe that the problem lies with the arc values I was given.  If one uses the radius value I was given of 597.96', then the desired 11-16-01 delta angle is achieved.
Message 8 of 9
wfberry
in reply to: wfberry
Revision:
Go to your Drawing Settings, Ambient Settings.
Under Angle, Change ANGLE Format to DD.MMSS (Decimal DMS)
Bill
Message 9 of 9
wfberry
Pervious method, NIL
OK, you are drawing a curve with anAutocad command.  If you use the following syntax it will work
11D16'11"
Rail Community
