i am using land desk 2009, can anybody help me out ?how can i interpolate existing levels from one existing surface to make uniform intervals, for example i have one existing surface which have 100 m length and width 50 m have some points, i need each 20m intervals levels to be plotted.
Solved by Neilw_05. Go to Solution.
thank you very much, yeah same what i want, still i have some clarification need if you dont mind please check attached sample file.
so its easy to understand from that file, which need that grid intersection to be interpolated, i apperciate your help. thanking you again, prasanth.
(Eclose:sample.dwg) if you know Liscad its easy to inetrpolate by rectangle area , it is possible in LD-2009?
hi thank you Neilw,
grid working fine i need to interpolate levels on that grid intersections, i want to create cross sections from eagle point, so this level interpolation required on 10 meter intervals, to get the cut fill volume accurate, i try this grid its ok, there is any other method u know i can make a boundary non standard size and inside that boundary i need full interpolated levels some areas are curved so that i can make cross sections accurate from eagle point.
regards prasanth.
thank you Neilw ,
appreciate your help , interpolating from surface with grid is enough , between two known points. method we have to click one by one x y offsets if there is any other method to put grid offsets together?
