Civil 3D Forum
Anybody else have this probelm??
14 REPLIES 14
Message 1 of 15
greenju17
514 Views, 14 Replies
It is random, but it mostly happens when Im switching from a layout tab to the model tab.  When I go to switch back to the model, nothing shows up in my drawing?  I try to zoom in and out, but it says "already zoom in/out as far as possible" and when I my cursor is just sitting on the screen, it gives reading to my alignments, but instead of giving me the station and offset, it says "value to large to format+t"????
The only way I can get my drawing back is to close out and re-open?  Is anyone else having this problem?  or know how I can fix it?
14 REPLIES 14
Message 2 of 15
AllenJessup
in reply to: greenju17
I haven't seen it. What version are you running?
Next time this happens. Try a Zoom > Extents followed by a Zoom > Object > Last. It might also help if you set a View for your drawing area and tried restoring it. I'm thinking that you have one entity way out in space and for some reason you're getting a Zoom Extents when switching back to the Model Space tab.
Allen
Allen Jessup
Engineering Specialist / CAD Manager
Message 3 of 15
greenju17
in reply to: AllenJessup
Im running civil 3d 2013
I have tried that and it doesnt help.  The only way to fix it is to close out and re-open, losing all my stuff I did inbetween saving and this happening of course.
Message 4 of 15
AllenJessup
If it's that serious. Have you considered a repair or a reinstall?
Allen
Allen Jessup
Message 5 of 15
greenju17
ok here is what I found.
I can get my drawing back if I create a window and zoom into it.  The problem is that Im zooming SO far away from it and I cant get back.  Not sure why its doing this?  just all of a sudden?
When I get zoomed back in, I can work in it no problem, but when I go to zoom-extents, I zoom way far out again and cant get back unless I do windows??  Its like something is out there, but I never did it before (and I have been working on the same drawing for 3 weeks)
Message 6 of 15
AllenJessup
Now I recognize the problem. When it happened to me. It turned out to be a leftover Transient Glyph. If that's what happened in your case. See: http://forums.autodesk.com/t5/AutoCAD-Civil-3D-General/AECC-TRANSIENTGLYPHS-What-is-it/m-p/2334464
Allen
Allen Jessup
Message 7 of 15
I know this does not fix your problem but could help you with working with the drawing that is causing it.
If you have alignments in the drawing as you mention, you can zoom to the alignment from the Toolspace.
1. Left click on the alignment name in the prospector tab of the Toolspace to select it.
2. Right click and select "Zoom to"
The above should zoom the drawing so that the alignment you have chosen fills the drawing area.
This also works for other civil 3d entities.
When you hit the point when you get the warning "Already zoomed out as far as possible" you can type RE and hit enter to run the Regen command which besides redrawing all the drawing entities will reset the zoom extents, allowing you to zoom out again. You might have to run the regen command again once you find your drawing objects.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 10 Enterprise 64bit
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2021
Message 8 of 15
so...I found out what my problem was.  The reason why my drawing is zooming far away is because of my cross section ticks for my r/w and utilities.  I add them to my cross sections, and when I hit zoom extents, my drawing is gone.  But when I take them off my cross sections, zoom extents works fine.  Glad that is all figured out
Now, the question is how do I get my ticks on my cross sections?  I created alignments down my r/w and utility lines, created a profile and proposed profile ( proposed for my ticks to follow), and added them to my cross sections.  Why is this not working??
Message 9 of 15
Jeff_M
S.W.A.G.: The block used for the Tick mark has a base point far away from the objects.
If you could post a drawing we may be able to do more than guess.
Message 10 of 15
Jay_B
If you're referring to applying Marker Styles to Section Views using "Profile Grade Lines" we get that here too.
A bunch of markers placed down around 0,0 which causes the view to be as you describe.
We have the insertion point of our blocks used in these Marker Styles set at 0,0 like Jeff suggests to be the cause.
Rather than have a bunch of weird block insertion points to worry about we just zoom around it here. Smiley Happy
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 11 of 15
greenju17
in reply to: Jay_B
I understand that, but I have never had this problem before.  I have inserted tons of ticks, base point 0,0,0, and this has never happend before.
Even if something is inserted at 0,0,0, you are still able to zoom extents, see everything, and zoom right back to your drawing.
attached is my drawing
Message 12 of 15
Jay_B
If I attach Markers using profile grade lines to Section Views I see this all the time here.
If some one has a way to avoid it I'm all ears because yes it can be annoying.
C3D 2018.1
C3D 2016 SP4
Message 13 of 15
Jeff_M
in reply to: Jay_B
OK, I'm seeing this as well in the drawing greenju17 posted. It appears to be a bug in C3d. It is locating the markers correctly in the X direction, but no Y direction offset is applied to place them in the correct locations in the sectionviews. Submit bug reports, if you haven't already.
Message 14 of 15
Jay_B
Our issue is a lot different in that all of the extra Markers we see are around 0,0 and I haven't seen the issue described in your OP where you see the"already zoom in/out as far as possible" message.
When I switch from Layout to MS things go back to where I was prior to the switch.
In the attached drawing there are many markers directly below the section view. Haven't seen that one.
One thing that's different in our workflow is the alignments used for the utilities are "Miscellaneous" type rather than Centerline, (not sure that would even matter).
And then the EG surface is sampled for the profile grade lines so the bottom of the markers tie to EG.
C3D 2018.1
C3D 2016 SP4
Message 15 of 15
tcorey
Like AllenJessup mentioned before, if you use the View command to create a model view (I call mine "Home") then no matter how far you find yourself away from the project, you can always type -v R Home and it goes back to where you want to be. It's really easy to set this up on a ribbon button if you don't like to type.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Rail Community
