AutoCAD Civil 3D General
tonnot
Message 1 of 3 (99 Views)
Ant way to have/create "free" frame views ?
99 Views, 2 Replies
09-05-2013 12:01 PM
That is .... I'd like to have a view frame not linked to any aligment, simply a view frame colletion.
The goal is to can create a VF for a cartography purposes or something similar. In example a 10x10 distribution schema.
A trick can be to use a "ghost "aligment , used only to served as environment to create the VF.
The main problem is the annoying link to aligment.
I suposse it is imposible to avoid this , isn`t it ?
What do you think? Thanks.
Civil 3D (2013) how much you have to improve....
*Expert Elite*
sboon
Message 2 of 3 (76 Views)
Re: Ant way to have/create "free" frame views ?
09-05-2013 03:02 PM in reply to: tonnot
Yep - you're stuck with an alignment.  Back in the "good old days" we used to run a no-plot alignment through all of our section views in the design drawing, so that we could create section sheet layouts in another file.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
*Expert Elite*
Joe-Bouza
Message 3 of 3 (62 Views)
09-05-2013 07:47 PM in reply to: tonnot
That sounds like a job for Map Books.
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
