I have also noticed that annotation does not work well with Civil 3D.
If I start a drawing using the default acad.dwt template and have simple
linework with annotative text and dimensions then there are no errors.
If I have any Civil 3D objects in the drawing, then annotation causes
errors like what you mentioned.
EB42
Civil 3D 2008 SP1
Quad Core Xeon
(3)250GB SATA Drives
2GB RAM
AnonymousChimp wrote:
> I recently decided to begin using annotative text styles and dimensions. So far, it has been an exercise in extreme frustration.
> I'll set the mood: Simple concept drawing set. All goes well until I begin to dimension and annotate my plans. (Annotated using quick-leaders.)
> Upon the introduction of annotative objects, drawing file becomes very unstable. Civil 3D crashes repeatedly - about every 5 minutes. It appears that there is a correlation between autosaves and crashes. I.e., mo
> re often than not, it appears that Civil 3D goes down soon after an autosave. (Only AFTER the introduction of annotative entities.)
> After each crash, I run a recovery on the dwg file. This is some of the log:
> Auditing Entities Pass 1
> Pass 1 18000 objects auditedAcDbSortentsTable(3F320)
> Error for Entry (45256) eInvalidInput was Removed.
> Error for Entry (45250) eInvalidInput was Removed.
> Pass 1 22600 objects auditedAc
> DbLeader(46142) annotation id Bad mtext id
> Disable annotation
> AcDbLeader(46148) annotation id Bad mtext id Disable annotation
> AcDbLeader(46162) annotation id Bad mtext id Disable annotation
> AcDbLeader(46168) annotation id Bad mtext id Disable annotation
> Pass 1 22700 objects auditedAcDbLeader(461B2) annotation id Bad mtext id
> Disable annotation
> AcDbLeader(461B8) annotation id Bad mtext id Disable annotation
> AcDbLeader(4
> 61C2) annotation id Bad mtext id Disable annotation
> AcDbLeader(461C8) annotation id Bad mtext id Disable annotation
> AcDbLeader(461D2) annotation id Bad mtext id Disable annotation
> AcDbLeader(461D8) annotation id Bad mtext id Disable annotation
> AcDbLeader(461F2) annotation id Bad mtext id Disable annotation
> AcDbLeader(461F8) annotation id Bad mtext id Disable annotation
> AcDbLeader(46202) annotation id Bad mtext id Disable an
> notation
> AcDbLeader(46208) annotation id Bad mtext id Disable annotation
> AcDbLeader(46212) annotation id Bad mtext id Disable annotation
> AcDbLeader(46218) annotation id Bad mtext id Disable annotation
> Pass 1 22800 objects auditedAcDbLeader(46232) annotation id Bad mtext id
> Disable annotation
> AcDbLeader(46238) annotation id Bad mtext id Disable annotation
> AcDbLeader(46242) annotation id Bad mtext id Disable annotation
> AcDbLea
> der(46248) annotation id Bad mtext id Disable annotation
> AcDbLeader(46252) annotation id Bad mtext id Disable annotation
> AcDbLeader(46258) annotation id Bad mtext id Disable annotation
> AcDbLeader(46288) annotation id Bad mtext id Disable annotation
> AcDbLeader(4628E) annotation id Bad mtext id Disable annotation
> AcDbLeader(46298) annotation id Bad mtext id Disable annotation
> AcDbLeader(4629E) annotation id Bad mtext id Disab
> le annotation
> Pass 1 22900 objects auditedAcDbLeader(462B8) annotation id Bad mtext id
> Disable annotation
> AcDbLeader(462BE) annotation id Bad mtext id Disable annotation
> AcDbLeader(462EA) annotation id Bad mtext id Disable annotation
> AcDbLeader(462F0) annotation id Bad mtext id Disable annotation
> AcDbLeader(4631C) annotation id Bad mtext id Disable annotation
> AcDbLeader(46322) annotation id Bad mtext id Disable annotation
> Pa
> ss 1 23100 objects auditedAcDbLeader(463D2) annotation id Bad mtext id
> Disable annotation
> AcDbLeader(463DB) annotation id Bad mtext id Disable annotation
> Auditing Entities Pass 2
> Pass 2 21600 objects auditedAcDbLine(44D0A) Null Owner
> Placed in $AUDIT_BAD_BLOCK_RECORD1
> AcDbLine(44D0B) Null Owner Placed in
> AcDbLine(44D0C) Null Owner Placed in
> Pass 2 23100 objects audited
> Auditing Blocks
> 200 Blocks audited
> Total errors found 39 fixed 39
> Running audit internally from the dwg file never returns an of the above issues. Upon entering my recovered dwg file, all of my quick-leaders are disassociated.
> Moreover, upon exiting Civil 3D to reboot, I receive the following error:
> INTERNAL ERROR: Attempt to access AecUiBaseServices after shutdown! (See attachment)
> Also, I am receiving the
> following on a semi-regular basis:
> FATAL ERROR: Unhandled Access Violation Reading 0x0004 Exception at 620651d0h.
> The 620651d0h bit of the note appears to be a hex memory address? Is this correct? Could I have bad RAM modules?
> Anyhow, I realize there is a lot to digest here. I hope I've been clear. I would appreciate any feedback as I am very frustrated right now..
> Thanks.
