Civil 3D Forum
Alley Corridor
8 REPLIES 8
Message 1 of 9
trynders
1274 Views, 8 Replies
Alley Corridor
Hi All,
What's the best way to model an alley with a 90 degree angle (turn).  Do I treat it as an intersection with a zero radius?  My typ section is 15 feet width with a 4% slope down to the center of pavement.  "V" bottom.  Not sure how to get it to model the outside corner and also eliminate the inside overlay.  Thanks,
8 REPLIES 8
Message 2 of 9
tcorey
in reply to: trynders
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 3 of 9
tcorey
I don't know if I would necessarily use the Intersection tools, but I would make a multi-baseline corridor to handle this.
If you're not familiar the feature, a Corridor can have multiple alignments defined as Baselines. Each will have its own design profile and assembly.
See the attached simple corridor with 90 degree corner.
Tim Corey
Redding, CA
Message 4 of 9
fcernst
in reply to: tcorey
I don't see the advantage of using a multi-baseline Corridor?
One baseline, and you would not have to monitor and update the common PVI across two profiles.
Fred Ernst, PE
C3D 2024
Ernst Engineering
www.ernstengineering.com
Message 5 of 9
trynders
Thanks tcorey,
I was going to take a look see but im using 2012 and apparently you attached a newer version.  Sad day.
Message 6 of 9
andrewpuller3811
Here is a blog post of mine covering this
http://andrewscivil3dstuff.blogspot.com.au/2011/06/create-corridor-with-90-degree-bend.html
and a similar topic with sample drawing is here
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Intersection-Design-90-degree-turn/m-p/3012576
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 10 Enterprise 64bit
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2021
Message 7 of 9
fcernst
in reply to: andrewpuller3811
Good show mate!  Let's kick it up a notch..   A mitered interior corner cleanup for the intersection:
One corridor, one assembly, one profile...fully dynamic.
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 8 of 9
BrianHailey
in reply to: fcernst
Care to share the drawing Fred? I would love to see your approach to this. I think I know how you did it but I'm not positive.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 9 of 9
tcorey
I like Fred's result as he is able to include cross secitons in the mitered area. Do you care to expound?
Tim Corey
Redding, CA
Rail Community
