Civil 3D Forum
All my drawing colors display as gray
19 REPLIES 19
Message 1 of 20
miker
15996 Views, 19 Replies
I ended my session yesterday, plotted my first layout, everything looks perfect.  I started up today and everything is gray.  Drawing layer colors are correct.  Everything looks ok in the properties pane when I select anything.  Print preview shows everything black.  Never had this happen before.  Solution?
Mike R.
19 REPLIES 19
Message 2 of 20
Jeff_M
in reply to: miker
Is "Display Plot Styles" checked in the Page Setup? If so, uncheck it.
Message 3 of 20
miker
in reply to: Jeff_M
Box is not checked.
Mike R.
Message 4 of 20
neilyj666
in reply to: miker
Occurring in model or paper space or both??
AEC Collection 2025 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 5 of 20
miker
in reply to: neilyj666
Both
Mike R.
Message 6 of 20
miker
in reply to: miker
Change layer setting.  Seems to have worked.
Mike R.
Message 7 of 20
miker
in reply to: miker
Not checked Michael Robertson CAD and Lab Operations Manager Blackburn Consulting :blocked::mailto:brendaf> Office: (916) 375-8706 Cell: (916) 717-9909 Fax: (916) 375-8709 e-mail: miker@blackburnconsulting.com 2491 Boatman Avenue, West Sacramento, CA 95691 :http:>:http:> www.blackburnconsulting.com:blocked::mailto:brendaf>
Mike R.
Message 8 of 20
miker
in reply to: miker
Both Michael Robertson CAD and Lab Operations Manager Blackburn Consulting :blocked::mailto:brendaf> Office: (916) 375-8706 Cell: (916) 717-9909 Fax: (916) 375-8709 e-mail: miker@blackburnconsulting.com 2491 Boatman Avenue, West Sacramento, CA 95691 :http:>:http:> www.blackburnconsulting.com:blocked::mailto:brendaf>
Mike R.
Message 9 of 20
in reply to: miker
Hi - Can you explain how you solved this issue in more detail? I'm having the same problem- layers show up as gray in both model and paper view but colors are correct in the properties pane.
Thanks!
Message 10 of 20
lorrie.bundy
in reply to: miker
Thank you for this post!! I had the same problem and the Display Plot Styles did not help.
I dont know what the solution was for the original poster, but
If you have been playing with maps and data connect, this may help.
Type in command line: mapwspace
Task Pane On/Off <on>:    hit enter to accept on
a task pane bar will load, you need to expand it by clicking on it (looks similar to prospector or panaroma bar).
Click on Display Manager tab, make sure Default is unchecked.
Solution also found here.....
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Lines-with-different-colours-look-the-same/td-p/42934...
Hope this helps!
Message 11 of 20
in reply to: lorrie.bundy
Just had this problem in AutoCAD Map 3D 2014 - solution still works - THANKS!
Message 12 of 20
miker
Thanks for the help!  My display plot styles box was checked by accident.
Mike R.
Message 13 of 20
Just thought I'd let you know your solution has just helped a colleague of mine retain his sanity after battling with the problem for hours!
Message 14 of 20
Yes!!!!!! thank you!!
Message 15 of 20
Same here!! THANKS!!!!!
Message 16 of 20
als553
THANK YOU!!!!!
Message 17 of 20
THANK YOU SO MUCH! 🙂
Message 18 of 20
This is awesome. Worked a charm! Thanks!
Message 19 of 20
23051998
Thank u very much bro. U the best solusion.
Message 20 of 20
hjward
lorrie...you just saved my life. I was about to end it all by running into traffic. I have spent the last 90 minutes or so pulling my hair out trying to figure out why all of my linework has turned gray.
Thank you so much.
Rail Community
