I have more than 100 alignments of a road network in Civil 3d. I want to assign seperate layer for each alignment. Is there any easy way to do this?
I changed the layers for a few alignments and exported them to Autocad 2007 format, but the centrelines were in single layer only.
Ajay Anand
CIVIL 3d 2011
DELL PRECISION T3500
You need to set up your Object layers on the settings tab prior to creating the alignments. You can add the name of the alignment to the base layer name
Joe Bouza
@Anonymous wrote:I have more than 100 alignments of a road network in Civil 3d. I want to assign seperate layer for each alignment. Is there any easy way to do this?
Ajay Anand
CIVIL 3d 2011
I think this is a style layer versus object layer issue. Copy the style that the alignments are on, change the layer in the new style, put one alignment on the new style. Then do the export again. I think the alignments will be on the layer specified in the style.
Mark Green
Working on Civil 3D in Canada
For the purposes of getting them to autocad in seperate layers try this -
Just had a thought about the effects the alignment style might have on the above procedure.
Make sure your alignment style that is used for all the alignments has the Layers for all the components set to layer 0 before you do the export to autocad format, or all the exported alignment components get put on the layer set in the alignment style rather than the layer the alignmnets are actually in.
I just tested and confirmed this behaviour. exporting the alignments with the alignment style component layers set to something other than 0 drops all the exported components into the layer set in the alignmnet style.
I tried like you said. But when imported all the alignments are taken into a single layer in the new drawing. New layers are not created.
Sorry, I wasn't real clear on which drawing you have to set your alignment style layers to 0. You have to set the layers to 0 in the alignment styles in the new empty drawing, not the one you are exporting from.
I would set the layers on all the alignment styles in the new drawing just in case, not just one.
I changed the alignment style layers to 0 in the new drawing. Every alignments are gone into the layer speciified in object tab of EDIT DRAWING SETTINGS OPTION
The tried with suffix and prefix to make layer with alignment names. That isn't working.
Can you attach the XML file with the alignments in it and what name you want as a prefix on the layers?
I will give it a go here.
I am attaching the xml file here. I will like to have each alignment in each different layer.
I want the alignment names as prefix or suffix for layer name.
Attached is a drawing based on the NCS metric template with modified alignment styles and drawing object layer settings. I used the NCS standard layer name and modified it to add the alignment name to the end for each alignment.
