Civil 3D Forum
Welcome to Autodeskā€™s Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D topics.
Showing results forĀ
Did you mean:Ā
Alignment table
9 REPLIES 9
Message 1 of 10
Neilw_05
821 Views, 9 Replies
Alignment table
I need to create a table to describe my alignments for the survey control sheet in my project. In Land Desktop we could use the Report tool in the Alignment Editer to generate a text file. I've looked at the preconfigured Station and Curve report in the C3D Reports toolbox but I don't like the format of the output, nor do I know how to edit it to get what I want.
What other options do we have for describing alignments?
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
9 REPLIES 9
Message 2 of 10
Jay_B
in reply to: Neilw_05
Neil,
Not sure what format your after but an alignment segment and curve table can be created like the example screen shot in This thread.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 3 of 10
Neilw_05
in reply to: Jay_B
I'm looking at the table option but it is not my ideal. I do like the Land Desktop format with the lines and curves compiled in a single table. If I could modify the default report it would be closer to what I want.
I'll put this aside and work on other aspects of the documents in case a better solution comes along.
Thanks for the suggestion Jay. The links will be helpful if I end up going that route.
WIN 10 64 PRO
Message 4 of 10
Line curve tables are no good?
Message 5 of 10
It's not my ideal. The default report is closer to what I want but it needs some tweaking.
WIN 10 64 PRO
Message 6 of 10
Neilw_05
WIN 10 64 PRO
Message 7 of 10
I should mention what I like about the report vs line and curve tables is the report lists the lines and curves in sequence which is easier to follow. Also I don't have to label the lines and curves with tags since the entire alignment is listed in context. Too it provides the tangent data both from PI to PI and also between curves.
WIN 10 64 PRO
Message 8 of 10
Jeff_M
You could edit the alignment geometry, view the geometry Grid View, Select All, paste into Excel, delete the columns you don't need, link that back to an Autocad table.
Message 9 of 10
Neilw_05
in reply to: Jeff_M
This is a nice compromise Jeff. Brilliant!
WIN 10 64 PRO
Message 10 of 10
try ran-pack.com they have a tool for alignment tables. i guess they will do you a free run
Rail Community
Ā
Ā
