Valued Contributor
darrell.wilmore
Message 1 of 3 (119 Views)
Alignment station justification
119 Views, 2 Replies
12-10-2013 08:07 AM
I have a novice problem that one of you older pros have a solution. There should be a simple solution but I can't seem to find it.
How do you change the station justification on an alignment? My stations are centered on the alignment and I want to move them perpendicular to the centerline and offset them to the left of the alignment. I pick the stations and get the label group ribbon but I can't seem to find the justification commands on the ribbon or under the properties dialog box. I do have them perpendicular to the alignment. I found that command.
Jay_B
Message 2 of 3 (113 Views)
Re: Alignment station justification
12-10-2013 08:25 AM in reply to: darrell.wilmore
Not sure exactly what your after but there is an X / Y offset value that may help to offset/justify the text in relation to the alignment & tic marks.
These are found on the "Layout Tab" in your alignment label style.
If it's the actual text you wish to justify then go to same Layout Tab>Text>Contents>Radio button>Text Component Editor>Format Tab>
highlight contents in view on right and choose the Right Arrow to push the new info to the viewer>OK
Jay
C3D 2014 SP2
Win 7 Professional 64 Bit
Valued Contributor
darrell.wilmore
Message 3 of 3 (106 Views)
12-10-2013 08:44 AM in reply to: Jay_B
Thank you for your time.
I found it.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
