Can I assign different station values to the same point on an alignment? we have pipeline work that has different ahead and back station values at different points along the alignment. This is useful with pipeline work where there was a change in the alignment geometry and rather than relabel the stationing, a different ahead and back station value is assigned where the geometry has changed
Solved by sboon. Go to Solution.
What you're looking for is a Station equation. Open the Alignment properties dialog and switch to the Station Control tab.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
