Civil 3D Forum
Alignment label (stations)
3 REPLIES 3
323 Views, 3 Replies
Hi friends,
I'm having problems with the alignment label. I'd like label the stations in intervals of 5 stations. For example, [0 + 0,00], [5 + 0,00], [10 + 0,00], etc. And the staions between each main station must be without label. How can I solve this question?
Thanks!
3 REPLIES 3
Jay_B
To fix the ones created you can do it this way.
http://forums.autodesk.com/t5/AutoCAD-Civil-3D-General/Change-Major-Stations-Increment-for-Multiple-...
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Jay_B
Also If you always label the alignment stationing at intervals of 5 you can set this up in your template by creating an alignment "Label Set" which has the desired interval specified for the "Major Station" type.
Then use this label set to add the alignment labels..
C3D 2018.1
C3D 2016 SP4
in reply to: Jay_B
Thank you so much, Jay! Your tips were useful!  Smiley Happy
Rail Community
