Is there a way to connect two sperate lines with a tangent curve wihout moving the two ends of the lines where the curve is connecting ?
I cant find a way to do it.
Thanks in advance.
Tony,
Solved by bobwesterman. Go to Solution.
Solved by odoshi. Go to Solution.
Hi Tony,
There isn't because there is no guarantee that the 2 lines are oriented in such a way that there is a curve solution that is tangent at both ends.
You could float a curve off the first line and specify a pass-through point at the start of the second, but the second point may not be tangent.
Better to use a Free curve that is "free" to slide at either end to ensure tangency.
Mike
