I'm trying to edit some existing alignments. When I create new entities, they do not show up in the alignment grid view. Why is this?
Solved by Jeff_M. Go to Solution.
Are you creating them running from low station to high? If you create objects in the wrong direction they don't show up in the grid view.
Post your drawing so I can take a look.
You don't change the station, you need to reverse the direction. If you draw 2 lines, one starting at (0,0) and ending at (0,10), and the other starting at (0,20) and ending at (0,10), you can make an alignment from one then add the other but only the first one will get stationed and show in the panorama because they are going in different directions. Use the ReverseDirection tool to switch the direction of the one not displaying and it will magically start working as desired.
I am also facing same kind of issue. I reversed the direction but labels and entities in grid view are not showing up. Please Help.
