AutoCAD Civil 3D 2012
Hey all,
I am trying to create an alignment from existing polyline that I had recieved from another companies drawing. It was alignment in their drawing but only comes through as linework. That's not the problem. The problem is that when I try and create a new alignment out of the existing polyline, the units are way off. the existing drawing had ticks every 100 feet obviously, but after I create my alignment, I get like 400-500 feet in before the existing one gets 100. Trying to find a scale issue, but not seeing one.
any ideas?
Thanks!
I hate to ask the dumb question here, but is it a 3d poly line? It needs to be a 2D polyline for the "Create Alignment from Objects" command to work properly.
Perhaps post a copy of the drawing in question, and we can narrow this down.
-owenmull
Hey,
Thanks for the reply. Well, I think I kind of figured it out. The incoming drawing with polyline was in engineering units. I switched the units over to Decimal and measured the polyline again. It was exactly 12 times larger. So, I scaled the incoming file down 1/12 and now everything is fitting so far. I know when we get some architecural files, etc. sometimes we have to do some scaling and I'm hoping that is the only fix. I'll re-post if I find an error with this change.
Thanks again!
Not a problem.
If only Architects could stop designing in fantasy units, the world would be a much better place.
I have a hard time explaining to Architexts why you can't put 1000 lbs. on a toothpick.........................
-owenmull
