How can you add the chord bearing, chord length, and tangent to an alignment table with the curve data in it? I have the length and direction but cannot figure out why the others will not load and update in the chart. Can someone help? I am using Autocad Civil 3D 2012
Solved by JoeLondon. Go to Solution.
Click on table, right-click, Edit Table Style. On the Data Properties tab, this is where you can add and edit the table information.
Already tried that and the column was added but I cannot get any info under the column for each curve.
You must click the add button (+), then double click the column value. Once you're in the text editor, you can add any property you want to that column.
ok now I see the problem. I do not have a option for the chord direction, or tangent length....pretty much the standard for curve data tables for surveyors to understand.
forgive me I am trying to use Civil 3D....I am use to the old autocads!
But Here i need the output in Autocad Civil 3D this type of curve table which we get in MX Road.
Please find the attached sample curve table drawing.
