Hello everyone, I was wondering if there is a way to import alignment styles from one drawing to another? I need a specific one and I would rather import it into my DWG instead of trying to match all the properties. Thank you
Zak
Find the style in question on the settings tab and drag and drop it into the dwg that you want. Further, I woud also add it to your standard template file if you like it a lot.
Thanks Eric. When someone is able to resolve their own issue like this, it's nice to still have the solution posted. It makes it easier for someone else that comes along searching for an answer to a similar issue (for those that actually do take the time to search first).
Don Ireland
Engineering Design Technician
I was typing my solution while he posted he solved it, I think.
