Something to consider...
with an alignment and a finished grade profile you could create an assembly
with a single node. A subassembly like LinkWidthAndSlope that is given a
width of 0 would accomplish this. Then you build a corridor. Lastly you
Corridor > Export > Corridor point as Cogo Points.
Angel Espinoza
KETIV Technologies
wrote in message news:5070479@discussion.autodesk.com...
i need to create points (x,y,z) from alignment stations with its elevations
derived from the finished grade profile.
is this possible without generating a finished grade surface, using only the
aligment and its finished grade profile?
thanks!
