Civil 3D Forum
Alignment Labels
11 REPLIES 11
Message 1 of 12
479 Views, 11 Replies
Alignment Labels
is there a way to add field properties to a station offset label, eg I would like to have a station offset labels that contains the area of a specific object.
11 REPLIES 11
Message 2 of 12
Not Acad objects, but IIRC you can add a Parcel Reference Text and have your object be called. That would assume your object would be acceptable as a parcel.
HTH
Message 3 of 12
this might get you thinking though it doesnt specifically address adding a
parcel reference.
http://www.civil3d.com/index.php?s=hold+offset
Dana Breig Probert, E.I.T.
Engineered Efficiency, Inc.
www.civil3d.com
www.eng-eff.com
Civil 3D 2007 SP2
AMD Athlon 64 X2 Dual Core 2.01 GHz
2GB RAM, 256 MB ATI FireGL V5200
wrote in message news:5341239@discussion.autodesk.com...
parcel.
HTH
Message 4 of 12
What i am looking to do is have a label that has the centerline stationing of a driveway along with the area of the driveway to do quantities with. Or I could use vba to pull the station and the area and put it in Acad text, but i do not know vba very well and have had trouble trying this.
Any suggestions
Message 5 of 12
Civil3DReminders_com
Depending on what you want your output to be you could use the object data capabilities in Map. The only problem is you would have to manually add the station information into each driveway polyline, but in the end you would have the ability to create annotation with the station and area or export the data and bring it back into a table indicating the station and the area of the polyline. Probably not the slickest method but doable. I have been explaining some of it on my blog, the only thing I haven't gone over is annotation, but the help files are adequate to figure it out.
http://civil-3d.blogspot.com/
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
Message 6 of 12
ah
this is how to do it......
i feel the urge to blog
back in a sec.
www.civil3d.com
www.eng-eff.com
Civil 3D 2007 SP2
wrote in message news:5342381@discussion.autodesk.com...
Any suggestions
Message 7 of 12
something like this?
www.civil3d.com
www.eng-eff.com
Civil 3D 2007 SP2
Any suggestions
Message 8 of 12
Yes that exactly what i want to do. Are you get this done with labels or text? manual or automated?
Message 9 of 12
secrets secrets
the blog post is coming- i just had images issues.
www.civil3d.com
www.eng-eff.com
Civil 3D 2007 SP2
wrote in message news:5342746@discussion.autodesk.com...
Message 10 of 12
i'd up
top post at civil3d.com
www.civil3d.com
www.eng-eff.com
Civil 3D 2007 SP2
"Dana Breig Probert" wrote in message
news:5342946@discussion.autodesk.com...
secrets secrets
www.civil3d.com
www.eng-eff.com
Civil 3D 2007 SP2
Message 11 of 12
Thanks for the help, I just have one more issue. When I make my line label I have the station called out before the area (eg. Sta. 24+34.00, CL of Drive, Construct 134 SF of 6" concrete drive.) the reference text being "Sta. 24+34.00, CL" and the text component being "of Drive, Construct 134 SF of 6" concrete Drive." but in the dragged state it puts the reference text under the text component if the Stacked text setting is used and if you use the As Composed setting then the leader will not flip if you move the Label. Is there something that i am missing.
Message 12 of 12
In our office we create a label for each side we want the text on. Not ideal but it is an easy solution.
Civil Reminders
Rail Community
