hello guys, I would like to label my aligment station by sequential numbering (ie. S1, S2, S3, etc.). I would appreciate very much if you could help me on this.
Solved by Jay_B. Go to Solution.
If I'm understanding correctly this can easily be done by editing the Major Station label style.
Settings Tab of Toolspace>Alignment>Label Styles>Station>Major Station>Label Name
Type text "S" in the Text component editor, preceding the "station value" property using output "left of station character".
wow after so many hours of searching I finally found it. than you very much. by the way my intention is to label the geometry points. anyway the concept is the same.
