How do I get the Alignment to "Come In" with the label set as I create the DREF? Currently I have to create the Data Shortcut, then edit the alignment label to add Major, Minor, Geometry Points... Is there a setting I am missing?
Solved by Jay_B. Go to Solution.
Specify the label set in the Feature Settings for Alignment.
Settings tab of Toolspace > Rt. click on Alignment > Feature Settings > Default Styles > Alignment Label Set.
It can alternatively be set in Alignment > Command settings for CreateAlignmentReference depending on your workflow.
My default Label Set is correct in this location. When I I create the shortcut the Label Set is "attached" to the alignment but no labels display and the attached image is what I see when I select the alignment to edit the Labels.
I know this is a simple question but are all layers on/thawed?
And within the styles included in label set are visibility values all set to "true"
Everything is on/thawed and visible.
It isn't really a display issue. As you can see in the Image "Once Reference is Created & During Edit" that once the reference is created no label types are added to the alignment automatically. I have to manually add each label type even though Major Station, Minor Station, Geometry Points and Station Equations are within the default label set as shown in image "During Reference".
Once I select the Alignment and enter the edit window for the labels and add the 4 types that i want to see and hit ok they display as wished.
In the "manual addition of labels.jpg" notice the label set "Style" values are blank.
If you navigate to the 1 in 100 ft ticks.... Label Set on Settings Tab of Toolspace,
are these entries also not populated here?
That's biggest difference I'm seeing when comparing to our workflow using 2014 SP2 here.
What SP are you using?
I think I attached what you are questioning.
It's all populated here but becomes "unpopluated" during the reference creation.
The files from which the shortcuts are created are 2012 files and I am currently using 2014. Could this be an issue?
I am using 2014 SP1
Now I see what you are getting as far as the styles populating! I corrected this in my Template and voila. Thank You very much for your help.
I will guess the differences can be attributed to attaching an older version to a newer version. AFAIK, attachments should be opened and saved to coincide with the current version.
Of course I would attached a COPY and not update the original.
Bill
Hi Bill,
This thread had to do with an Alignment Label Set which was absent the necessary "Style" entries within the Alignment Label Set dialog..
Assuming you were thinking it was xref related?
