AutoCAD Civil 3D General
Active Contributor
ScotBIM
Message 1 of 9 (628 Views)
Accepted Solution
Alignment Label Anchor Point (Dragged State)
628 Views, 8 Replies
04-16-2010 03:02 AM
I am having an issue with the dragged state of a PI label on a curve if the label has been dragged.
When the label is created I have the label as I want it, with a triangle at the PI point with the text next to it, but when I drag it the leader then points at the middle of the curve and not the PI position.
In "Layout" in label Style Composer I have stated that the anchor point is the Intersection Point, and of course it is, but when I drag it the leader does not point there.
I need to use the curve label here, as the table tag also populates a table with all the curve data.
See attached image of label prior to and post drag,
Active Contributor
ScotBIM
Message 2 of 9 (425 Views)
Re: Alignment Label Anchor Point (Dragged State)
11-25-2012 03:17 AM in reply to: ScotBIM
... Forgive me replying to my own old, old post - but two years later and two releases later this is still an issue, so deserves a bump, but the problem now is specifically with the start and end of a curve - the dragged leader always points at the middle of the curve and not the start or the end.
Also searching through other posts other users are also suffering because of this in other parts of Civil3D.
>>>> I have now added this to the dark well of the Civil3D Wishes forum...
*Expert Elite*
BrianHailey
Message 3 of 9 (412 Views)
11-25-2012 08:28 AM in reply to: ScotBIM
It seemed to work just fine for me:
http://screencast.com/t/5AgYwZZfk
What type of label are you using? I used a "Point of Intersection" label:
http://screencast.com/t/740ckSPq
Active Contributor
ScotBIM
Message 4 of 9 (399 Views)
11-25-2012 08:23 PM in reply to: BrianHailey
Brian, see my second post: the issue now is not with the PI, but the PC and PT.
The label inserts at the correct position, but once dragged the leader points not at the start or end of the curve but the middle.
As this is essential for our delivery, this necessitates our users to laboriously go to to every curve on the alignment and drag the label leader from pointing to the centre of the curve to either the start or the end.
*Expert Elite*
BrianHailey
Message 5 of 9 (390 Views)
11-25-2012 08:57 PM in reply to: ScotBIM
Still works just fine for me. What method are you using to add the labels?
http://screencast.com/t/9zrxOdoH
Active Contributor
ScotBIM
Message 6 of 9 (387 Views)
11-25-2012 09:18 PM in reply to: BrianHailey
Pick alignment;
Ribbon: Add Lables > Multiple Segment.
See below - the anchor point on the Label Style Composer states "Start", but the leader is pointing to the middle of the curve.
*Expert Elite*
BrianHailey
Message 7 of 9 (369 Views)
11-26-2012 01:55 PM in reply to: ScotBIM
Try using the geometry labels instead. Grab the alignment, right click, add/edit labels (or something like that).
Active Contributor
ScotBIM
Message 8 of 9 (355 Views)
11-26-2012 09:14 PM in reply to: ScotBIM
Brian - thanks, that is a solution that works - makes you wonder though why have Alignement Labels AND Geometry labels doing the same function?
Cheers.
*Expert Elite*
BrianHailey
Message 9 of 9 (315 Views)
11-30-2012 05:48 PM in reply to: ScotBIM
Because someone would say, "How come I can't add this information to my curve label?" In your case, you weren't labeling the PC and PT, you were labeling the curve and configuring the curve label to add PC information at the PC and PT information at the PT. When you take that into the dragged state, it points to the thing you were labeling - the curve.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
