I have made an alignment which should be around 6km but when I add the station labels it stops at 1+061. In the alignment properties the end station is 1+061, so for some reason it is like that the remaining of the alignment is not recognized even if it shows on screen and is selected when I click on the alignment.
What can I do to have the entire alignment recognized without redoing it all over?
Thanks!
Look closely at station 1+061 and you should see a break in the alignment. Simply grip edit the loose end back to the recognized part of the alignment and you should be good to go.
