AutoCAD Civil 3D General
Distinguished Contributor
onsionsi1
Message 1 of 5 (160 Views)
Alignment(Compound Spiral in Loop)
160 Views, 4 Replies
05-09-2012 04:05 AM
Hi evreyone
Can someone help me how to draw an alignment for the attached file
I have two main road one of the is tangent and other one is spiral so i would like to draw loops with S-C-S
I face many problems to draw that in attached file
So how can i do that in civil 3d 2012
Your advice will be appreciate.
Thank you.
Please do not forget approve as solutions and Points
to Remember Please Accept as Solution and Kudos Please
Employee
peterfunkautodesk
Message 2 of 5 (154 Views)
Re: Alignment(Compound Spiral in Loop)
05-09-2012 05:36 AM in reply to: onsionsi1
Start by drawing the tangents. Make sure they are going the correct directions. The second tangent won't station after it is drawn because it isn't connected to the alignment.
Second, use the SCS element to connect the end of the first tangent to the start of the second. There is an option to allow the curve to be greater than 180 degrees, use that to produce the loops that you need.
Cheers,
Peter Funk
Peter Funk
onsionsi1
Message 3 of 5 (151 Views)
05-09-2012 05:53 AM in reply to: peterfunkautodesk
Thank you Mr. Peter for your reply
But my issue here is how to attach S-C-S to Spiral and tangent (both edges are spiral and tangent)
For your advice
Thank you
Employee
peterfunkautodesk
Message 4 of 5 (149 Views)
05-09-2012 06:04 AM in reply to: onsionsi1
OK, I mistook the spiral as a tangent.
The SCS element will only work between two tangents. If you want a dynamic solution than you're going to have to make a short (very short) tangent at the start of the out spiral.
If you know the values of all the curves and the spirals then you can use the floating and fixed elements to build up the loop.
Peter Funk
Peter Funk
onsionsi1
Message 5 of 5 (145 Views)
05-09-2012 06:49 AM in reply to: peterfunkautodesk
Thank for your advice and i will try this solution
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
