Not sure but does the rotate definition in the style have anything to do with it?
same thing here - need to rotate surface labels as the site was originally on assumed coords
Help please
we cant be the only people who have encountered this
thanks
Not sure which version added the ability to give Surface labels a rotation. In 2012 you can edit them individually either in the Properties Palette or using the grips (after the label is selected and grips are displayed, hover over the square shaped grip). You can also select many and change the Label rotation in the Properties palette.
using 2012
not individual rotations - the whole site was moved and rotated - I need to rotate 100's of labels to the new orientation
So select one, right-click, Select Similar, go to the properties palette and enter the desired rotation. If you don't know what angle to use, then rotate just one first to where you want then observe, or copy, the angle in the Properties Palette, then do as above.
thats not it -
the entire site has moved and was rotated so all the labels for the surfaces have to be moved and rotated aswell (as in all together around a common point - not just the orientation of the text in the label or the marker - the actual label has to be rotated)
I can move them fine but I cannot rotate them andd align will not work
I also tried making them a block but once I explode they go back to where they were
see the labels out in the parking lot - need to all be rotated to the new orientation
thanks for the reply - at least I know it cant be done - def a wish list item
