At unpredictable times, and only in paper space, we see a tiny white rectangle. We cannot select this object, or zoom in on it; it maintains its size at any scale, although it will move if one pans the paper space view. It does not appear at the UCS origin or at any other discernible reference point; it disappears if one moves the cursor off the drawing and onto, say, the ribbon, but reappears once one begins to work in the drawing area again.
What is it? How do we get rid of it? It's like being bugged by gnats on a hot day. I append a screenshot with the subject entity outlined in green at the lower left.
Thanks!
It's a big file.
My problem is that this object appears only intermittently; I can't get it to appear on purpose.
On the other hand, the matter may not be sufficiently critical to post a file of this size. It's more on the order of hourglass-as-cursor-in-layer-list-window magnitude, an irritant rather than a life-threatening assault.
Thanks anyway.
Let's look for patterns as to when it does/doesn't appear.
Don Ireland
Engineering Design Technician
