AutoCAD Civil 3D General
*Expert Elite*
Jeff_M
Message 11 of 16 (364 Views)
Re: Adding to an existing alignment
06-28-2012 08:03 AM in reply to: jamesmac1200
When adding to an alignment, the objects you are adding must be drawn in the same direction as the alignment. If you reverse the segments (not the alignment) they should then be correctly recognized.
For those who say to stretch the alignment and add the objects internally, I say that I've never needed to do so. Making sure to draw in the correct direction has always worked for me.
Edit -  I see the OP found this out as I was composing this message.
Active Contributor
jamesmac1200
Message 12 of 16 (359 Views)
06-28-2012 09:29 AM in reply to: Jeff_M
Right on the Money! That was exactly what I was getting at. Thanks again.
Civil 3D 2012
Intel Xeon W3520 @ 2.67 GHz
10GB RAM
64-Bit
Window 7 Professional
Member
Message 13 of 16 (327 Views)
08-02-2012 08:46 AM in reply to: Jeff_M
Hello, I am trying to perform this operation also, and can't seem to get it to work.  My problem is extremely simple: I'm merely adding a tangent line to the beginning of an alignment I already had established.  I can't seem to get Civil3D to actually update the alignment with the new segment.  When I select the new segment (or anywhere on the alignment) it all selects together as though it's part of the alignment, but the segment does not show up in the grid view table and it does not get stationed, etc. in the drawing.
I've tried reversing the segment, and that does not seem to make any difference.
What am I missing?  This is such a simple operation, it's rather frustrating that Civil3D can't seem to get it (or that I can't seem to get Civil3D in this case).
Thanks for any help you can offer
Active Contributor
jamesmac1200
Message 14 of 16 (323 Views)
08-02-2012 10:06 AM in reply to: Kenneth_L
Good morning,
Please see attachment. I threw this together quickly to illustrate the process. I think this is what you are looking for. Just remember when you are adding segments to an existing alignment, for best practice, go in the same direction as your alignment. This is expecially important if you multiple segments, curves, etc. Just FYI, the green line in the example is just a polyline to trace over.
Civil 3D 2012
10GB RAM
64-Bit
Active Contributor
jamesmac1200
Message 15 of 16 (321 Views)
08-02-2012 10:12 AM in reply to: Kenneth_L
Sorry, here is the right attachment.
Civil 3D 2012
10GB RAM
64-Bit
Member
Message 16 of 16 (318 Views)
08-02-2012 10:30 AM in reply to: jamesmac1200
Great, thank you!  I tried re-doing the line starting away from the beginning of the alignment and ending at the end of the existing alignment, like you showed, and that has done the trick.  Apparently Civil3D doesn't like it when the line is drawn the other direction, even if you later reverse the line.
Thanks again!
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
