AutoCAD Civil 3D General
Distinguished Contributor
Message 11 of 14 (229 Views)
Re: Adding profile elevations to alignment labels
11-28-2012 07:50 AM in reply to: tr4driver
I've had some users ask me to provide some screen shots of how you go about this, so after a hiatus from the discussion forums, I'm back to post this- hope it helps.  This is done with Civil 3d 2010, so not sure how the newer versions are handling it.
First you need to modify your alignment major and minor alignment labels and/or create new ones to use a Profile Reference Text as part of the label.  We only show majors, so that is all I modified.
Continue with:
Once you have style set up like you like, then you apply the labels to your alignment.  Again, we just show majors, so that is what I showed here.  The KEY here is to follow step one of the picture below.  I'm using Civil 3d 2010, so with that version you have to hold down the control key while you window select all your labels.  Then procede to properties window and change the pulldown to just your individual labels selected.  Pick green box (not shown in pic) and follow prompt in command bar.
After that, you should see the below result.  Note- if you adjust your profile (drag vpi's, ect), these alignment labels update in real time.
Hope this helps those that are stuck, especially if you are stuck with the ??? in your labels.  I have read somewhere else where the profile association can get lost or the labels do not update when you edit your profile.  I have yet to experience it, so I'm not sure what to do other than to re-label your alignment.
-Bryan
Bryan_S
Windows 7 Home Premium SP1
3.60 GHz AMD FX-4100 Quad-Core 64bit / 6gig ram
Nvidia Gforce 9600 GT O.C.
New Member
Message 12 of 14 (49 Views)
03-16-2014 10:36 AM in reply to: tr4driver
Hello, i tried to do the same on 2014 (but for minor stations). I created the new label style, choosing "reference text" and changed his contents to "profile elevation" (as you showed).
All went well until i start doing the second part: when i select the "minor station label group" i'm not able to see the info about "reference text objects", and so i cant do the next steps...anyone can explain me the problable cause? Thanks a lot!
*Expert Elite*
Jeff_M
Message 13 of 14 (43 Views)
03-16-2014 11:52 AM in reply to: patriciasilvaferreira
Hi! Welcome to the forums, Patricia!
Are you holding down the CTRL key when selecting the labels? I just tested this in 2014 with minor station labels and it works perfectly.
Jeff_M, also a frequent Swamper
New Member
Message 14 of 14 (38 Views)
03-16-2014 12:00 PM in reply to: Jeff_M
i just select objects by picking on then, but without control button pressed and the result was no quit the same... now its working like it should! thanks a lot for your fast and great help!
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
