Hi.
I'm looking for a way to add a marker with location & elevation data to the profile (not the bands).
Only mention i found in this forum was for civil2011 (i have 2013) and it is no longer available.
Thanks.
Solved by troma. Go to Solution.
please ellaborate. Are you wanting tick marks on the profile for high and low points in VC?
Your Name
Mark Green
Working on Civil 3D in Canada
Your Name
Thanks.
I'm not clear on what VC means, i'm quite new to civil3d.
I've figured out how to add labels that note the station and elevation via Station elevation in "Add view label". My problem is that there are no snap points in the profile to indicate the position of the min/max point and so i need to draw lines and place the block near the profile (since the profile line does not allow snap).
If anyone has a better method and can provide an explenation on how it's done, i'd be gratefull.
Your Name
Not sure why you can't snap to the profile, I normally can.
However, I think there's a better way. Do you want labels on all grade changes (PVIs), or just where it is a high point or a low point?
If it is all of them, make a profile 'Grade Break' label, rather than a profile view label.
Mark Green
Really appreciate all your help, in the short time i have been posting questions here, i got so meny helpfull responces it's overwhelming. THANK YOU
Back to our regular programing...
By min/max points i mean high/low points (english isn't my first language and some of the technical terms get lost in translation).
For some reason (i have yet to talk to our local autodesk dealer for support) i can't snap to the profile or the table itself. This makes my life alot harder than they need to be. so placing tags manually on the high/low points is doable, but time consuming, specially with a project that has meny roads and some are quite long.
I only need the high/low points, i allready know how to place grade data in the table and the profile.
I would still do it with a Profile 'Grade Break' label, but you have to test to see if it is a high/low point first. You can do this with an expression.
You can appreciate that for high/low points, the {Grade In} and {Grade Out} will have opposite signs—one is positive and the other is negative. Whereas for other grade breaks, they are either both positive or both negative. You can use this to create your logical test. I think this should work:
IF({Grade In}*{Grade Out} <0, (your text height in either feet or metres) , 0)
The multiplication of {Grade In}*{Grade Out} will always be less than zero ( a negative number) for high & low points, and greater than zero for the others. Use the expression to set the text height of a label component that labels the station and elevation of the grade break.
Mark Green
Your Name
Again, thank you.
I'm, quite new to civil3d. The expressions your talking about are suppose to be written as formula when i create a new tag style?
Mark Green
Mark Green
I think I agree. Can you post the pseudo code so I can understand how that call works?
Your Name
Mark Green
Your Name
We'll get it straightened out. I asked troma to give it a look over - screwed something up in the definition.
rename extension to dwg
Your Name
