Civil 3D Forum
Adding .NET info to a Title Block?
2 REPLIES 2
everblader
233 Views, 2 Replies
Is there a way to display the projection (FL-W83) or Datum (NAD83) of a DWG file in the titleblock? Maybe using fields, or a diesel expression of some sort? I belive the information resides in the .NET framework, how can I get that into my titleblock?
HP Z400 Workstation
Intel Xeon W3550 -Cores 4
12GB Triple-Channel DDR3 @ 533MHz
2-HP LE2201w @ 1680x1050
ATI FirePro V3800 (FireGL) (HP)
MS Windows 7 64-bit
2 REPLIES 2
Jeff_M
in reply to: everblader
You don't need .NET to get this (although you could if you want), it is accessible using the COM API meaning you can use some simple lisp to get the info. Then you could populate the attributes in the titleblock with the desired info: If you need help with the editing the titleblock, there are plenty of posts in the AutoCAD customization -> lisp forum.
(vl-load-com)
(setq prod (vlax-product-key))
(setq prodStr (strcat "AeccXUiLand.AeccApplication"
		      (cond ((vl-string-search "\\R17.0\\" prod)
			     ".4.0"
			    ;;2007
			    ((vl-string-search "\\R17.1\\" prod)
			     ".5.0"
			    ;;2008
			    ((vl-string-search "\\R17.2\\" prod)
			     ".6.0"
			    ;;2009
			    ((vl-string-search "\\R18.0\\" prod)
			     ".7.0"
			    ;;2010
			    ((vl-string-search "\\R18.1\\" prod)
			     ".8.0"
			    ;;2011
			    ((vl-string-search "\\R18.2\\" prod)
			     ".9.0"
			    ;;2012
			    ((vl-string-search "\\R19.0\\" prod)
			     ".10.0"
			    ;;2013
			    (t "")
(setq *acad* (vlax-get-acad-object))
(setq C3D (vla-getinterfaceobject *acad* prodStr))
(setq C3Ddoc (vla-get-activedocument C3D)
      settings (vlax-get c3ddoc 'settings)
      dwgstg   (vlax-get settings 'drawingsettings)
      zonestg  (vlax-get dwgstg 'unitzonesettings)
      coordsys (vlax-get zonestg 'coordinatesystem)
 from that final variable you can get the properties you need:
(vlax-get coordsys 'cscode)
(vlax-get coordsys 'datum)
(vlax-get coordsys 'description)
(vlax-get coordsys 'projection)
(vlax-get coordsys 'unit)
 You probably just need the first 2.
Jeff_M, also a frequent Swamper
everblader
in reply to: Jeff_M
Thanks, I'll give it a try.
HP Z400 Workstation
MS Windows 7 64-bit
Rail Community
