AutoCAD Civil 3D General Discussion
evecin88
Message 1 of 12 (564 Views)
Add text to sit on a polyline
564 Views, 11 Replies
10-08-2013 08:01 AM
Hello everybody,
Recently my company has changed the standards to label existing utilities with text right above the utilitie lines without leaders. I would like to do automate this process somehow using attributes or something similar to that. I have attached a screen shot of how I would like it to look. The objective is to speed up the labeling process.
Thanks!
*Expert Elite*
troma
Message 2 of 12 (546 Views)
Re: Add text to sit on a polyline
10-08-2013 08:41 AM in reply to: evecin88
You could make a line label to say that. But if you're looking to pull attributes out of the linework...have you looked into using pipe networks?
Credit where credit is due! Give kudos or accept as solution whenever you can.
evecin88
Message 3 of 12 (538 Views)
10-08-2013 08:53 AM in reply to: troma
Thanks for the response. Yes we do use pipe networks however that would be more time consuming than what I was thinking of. Can I convert a polyline In a way that it has its own labels like pipe networks?
*Expert Elite*
Joe-Bouza
Message 4 of 12 (529 Views)
10-08-2013 09:07 AM in reply to: evecin88
If not a lable style you can alway make a lintype to do that by layer, block or entity
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
evecin88
Message 5 of 12 (522 Views)
10-08-2013 09:16 AM in reply to: Joe-Bouza
Can I make a linetype with text offset up from the center? Also I heard of something called text wave doing this but I can't find it anywhere. Thanks!
*Expert Elite*
Joe-Bouza
Message 6 of 12 (518 Views)
10-08-2013 09:25 AM in reply to: evecin88
you can make any offset. the issue I see coming is do you not want it to repeat? complext ltypes will repeat the text at a defined interval relative to the dwg scale
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
Valued Mentor
dmartin
Message 7 of 12 (515 Views)
10-08-2013 09:32 AM in reply to: Joe-Bouza
The way i have dealt with this issue at my company is to use dynamic blocks. I gave created a block containg specific texts, for example APP RW. Within the block I put a dynamic alignment point set to tangent. I then have multiple Tool palletes that contain the various blocks. So in the end I select the text I would like to attach to the line, put it near the line, reselect the text and use the grips to have it attach to the line I choose.
Dave
Civil 3D 2013
HP Z400 Workstation
6GB of RAM
296GB HDD
ATI FirePro V5700(FireGL)
Win 7 Home Professional
Please use Kudos Where Deserved
*Expert Elite*
Neilw
Message 8 of 12 (499 Views)
10-08-2013 10:10 AM in reply to: evecin88
You might find the Map the annotation tools helpful as well. You can apply object data to the lines and it will be used in the labels. Changes to the object data will be propogated to the labels. If the lines move, the labels will follow.
I'm not sure if we can make the labels align to the line though. Will have to run some tests later.
Neil Wilson (a.k.a. neilw)
Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
WIN 7 64 PRO
HP Pavillion h8xt, i7 2600, 12 GB
RADEON 6450, 1 GB
http://www.sec-landmgt.com
evecin88
Message 9 of 12 (488 Views)
10-08-2013 10:21 AM in reply to: dmartin
Thanks Dave, that would be a possibility if I don't find a more automated and quicker way to do this.
evecin88
Message 10 of 12 (477 Views)
10-08-2013 10:22 AM in reply to: Neilw
Neil, this sounds very interesting. I have never played with those functions. I will research them. If you do find anything I would appreciate your further input. Thank you!
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
