Civil 3D Forum
Add specific, individual, non-interval contour lines to surface
11 REPLIES 11
Message 1 of 12
8595 Views, 11 Replies
Is there a way to add an additional, individual contour line to a surface at a specific elevation?  For example, if we are creating an as-built surface that includes a pond, we might want to have a contour at the top of the pond, or if we are creating a proposed surface, we might want to add a contour line at some proposed normal pool elevation, neither of which will probably fall at an even foot.
Thank you,
11 REPLIES 11
Message 2 of 12
Jeff_M
User-defined contours.....make sure your Surface style is set to display them, then in the Surface properties, Analysis tab, select User defined Contours for the Type, enter 1 for the range, then change the elevation to the one you want in the Range Details panel.
Message 3 of 12
Jeff,
Thanks again.  You've been such a help today.
Message 4 of 12
Joe-Bouza
Yes, that is a "user contour", define it in the surface properties analysis tab>> analysis type >>> user defined contours. You can make as many as you like. One caveat; your surface style needs to be set to display "user contours".
Joe Bouza
Message 5 of 12
jmayo-EE
Oh, it's not just today. 😉
John Mayo
Message 6 of 12
Jeff_M
Glad I could help, Tom.
If you find a response which answers your question, please be sure to accept it as the solution. This will help future searchers quickly find answers to their own questions. Thanks!
Message 7 of 12
in reply to: Jeff_M
Now how do i extract these user defined lines and have them stay when i switch back to 1 foot contour surface? Extract button is deleting them when i change surface back to one foot contours.
Message 8 of 12
neilyj666
Use the Extract Objects from the Surface Tools Panel from the contextual ribbon when you have the surface selected
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 9 of 12
in reply to: neilyj666
I do that and it extracts but then when i switch back to any other surface style them lines are gone.
Message 10 of 12
Jeff_M
Are you actually extracting them? The extracted objects are polylines and no longer have any ties to the surface or style.
Message 11 of 12
in reply to: Jeff_M
Yes and they become polylines (actually creates two polylines on each one), but when i switch surface style back there is a hole there where they were. It used to work. I am in ACAD 2014.
Message 12 of 12
shadysuliman15
i was able to add the user contours for the contour elevation i wanted for my pond but whenever i try to edit surface after that (swap edge, add surface point) the user contours get deleted, any idea on what this may be?
Rail Community
