Civil 3D Forum
Add pipe sizes (Box) 2015
9 REPLIES 9
Message 1 of 10
rkmcswain
466 Views, 9 Replies
Apologies if this has already been mentioned elsewhere.
Ran into this issue this week. If you have time, can you check it on your setup?
  1. Using the stock OOTB imperial template, open a new drawing.
  2. In the Settings tab of the toolspace, go to Pipe Network > Parts List
  3. Right Click on Storm Sewer and choose Edit.
  4. In the Dialog that opens, go to the pipes tab, Expand Storm Sewer, then expand Concrete Box Culvert
  5. Right Click on the only entry there (24"x24"....) and choose Edit.
  6. Click on the "Inner Pipe Width" column.
  7. Civil 3D crashes with an UNHANDLED EXCEPTION (it may take a few seconds).
The only "oddity" about the machines we are seeing this on, is they either _had_ or still _have_ an earlier version installed (2013 or 2014).
I do not have a machine ready that only has a fresh 2015 install on which to try this.
But it's repeatable on all of our other machines, regardless of template, login, etc.
I have already submitted a subscription support request.
(Lastly: It also only seems to crash when adding a size to "Concrete Box Culvert" - other pipe shapes work OK.)
TIA.
R.K. McSwain     | CADpanacea | on twitter
9 REPLIES 9
Message 2 of 10
odoshi
in reply to: rkmcswain
Yup. I edited that dimension and OK'd back to the parts list. Then went in to edit it again and it froze.
Interesting thing was there were duplicate entries for that dimension. So 4 or 5 sets of 24" followed by 4 or 5 36", etc.
Locked me up and so I ended the task. My laptop only has ever seen 2015 installed. No prior versions.
Mike
Mike Caruso
Autodesk Certified Instructor 2014
AutoCAD/Civil 3D Autodesk Certified Professional 2014, 2015, 2018
www.whitemountaincad.com
Message 3 of 10
Jay_B
I eventually get a blank 24"x24" box culvert dialog, c3d freezes / end task.
Also seeing the duplicate size entries Mike mentioned.
When trying to pick one of these duplicate entries the field would often populate w/ a value
different than what was selected. 2015 SP1.
All versions 2012 though 2015 installed.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 4 of 10
rkmcswain
I couldn't get this recorded last night, but here you go.
Message 5 of 10
Jay_B
Can't duplicate the Fatal Error here but get this when trying to edit using your same steps > End Task.
C3D 2018.1
C3D 2016 SP4
Message 6 of 10
rkmcswain
in reply to: Jay_B
Thanks for checking this out. Now at least I know it's not isolated to our environment.
Message 7 of 10
rkmcswain
Response from Autodesk. Emphasis added by me.
Thank you for contacting Autodesk Support. My name is xxxx xxxxxx and I would like to inform you that the issue you have reported is a known issue to the development team and they are working to resolve the issue. I am going to link your case to the reported known issue.
I apologize for the inconvenience that this issue may cause. Please make sure that you keep your product up to date with the latest Hotfixes, Service Pack and release to ensure that you take advantage of this, and other, fix as soon as it is available.
I am going to go ahead and close this case at this time. If you have further questions regarding this issue, you can reply to any of the case emails within 30 days to reopen the case.
Message 8 of 10
wfberry
I bet Autodesk has more CLOSED CASES than Carl Sagan could count.
Bill
Message 9 of 10
twait
in reply to: Jay_B
I'm experiencing this as well.   Blank dialog pops up when editing a pipe in a parts list and freezes C3D.
Message 10 of 10
diegoal
in reply to: twait
Hey guys, I'm getting the same problem here.
Please, let us know if it is solved.
Diego Álvares
Civil Engineer @ Trento Engenharia Ltda.
www.trentoengenharia.com.br
Autocad Civil 3D 2010 to 2017 - Infrastructure Design Suite
Windows 7 64 i7 4770 @3.40GHz 8GB Ram GeForce GTX 760
Please use the Accept as Solution or Kudo buttons when appropriate
Rail Community
