Hi All,
I am using Civil 3D 2013 for mapping survey topography work and have liked the ability to xref site photos onto the location that I snapped the picture from. In the past I have stored the .jpg photos on our network drives and C3D has done exactly what I wanted, placed a very small image on my drawing that you can zoom in on to see site details. We are moving to a Sharepoint environment for storing photos, so one of my first experiments was to try to xref a photo from there. I used the Attach Image ... option as usual, then used the Search the Web tool and navigated to my photos. That all worked as before with the file based system and I was very happy. The next time I opened the drawing the images were not there. I looked at the reference and found that it was not pointing to the URL I had navigated to, but to a copy in C:\Users\....\Temporary Internet Files\... \12StreamSurveyingIsFun[1].jpg which I assume gets flushed out whenever the temporary files get cleared. This is not going to work for my purposes.
My question is can I make a reference to a URL that is persistent? I am not clear on why the xref was pointed to my temporary internet files instead of the web location that I selected.
This does not answer your question directly but I have just finished a large topo project and just by luck came up with this:
1. Using my iPhone and an app called THEODILITE HD.
2. Using a couple of routines that come with ToolPac and Mapworks from Dotsoft.
My drawing file is setup for my State Plane coordinate system.
These pictures have all this information embedded in them and a small block is inserted on the layer of my choice and at the location that I was standing and the block arrowhead is pointed in the direction I was taking the picture. BTW, I inserted these blocks 75 ea. at a time from 3 different directories.
Once installed, all I have to do is run the Image Inquiry Routine and drag my cursor over the block and that particular picture is shown. As I move the cursor across the screen every time I pass a block a picture jumps up and doesn't leave until I hover over the next block.
It is fantastic. It adds hardly any size to the drawing file.
BTW, I have no connection or monetary advantage here other than using these products.
Bill
Seriously if anyone wants to know more, I will be happy to relate. I cannot tell you how much time this has saved me.
Bill has all our products so he has a lot of additional functionality to choose from.
The ability to view hyperlinked images by simply hovering the cursor is in both ToolPac & MapWorks.
Since geo-images are in Lat/Long, the image symbol place is only in MapWorks Base (since it has projection support).
Even though your ToolPac version is very old, you can always upgrade. Drop me an email if you're interested.
Finally got around to making some rough demo videos of this.
Placing the symbols into a drawing:
http://www.dotsoft.com/demos/mwPrjImgExi.htm
Inspecting the linked images by hovering:
http://www.dotsoft.com/demos/mwImgLnkIns.htm
