I have created cogo points for field staking. I'd like to share them through the survey database.
Can I add the points to the Survey Database without first having to export them to a file?
Thanks!
C3D 2013. Windows 7.
Solved by ToddRogers-WPM. Go to Solution.
Yes you can. If you right-click on the survey database, you have the option. See below...
