Civil 3D Forum
Add Station and Offset to a point
4 REPLIES 4
mnyrac
6779 Views, 4 Replies
I currently have a drawing with a road alignment and stationing.  Is there a way to automatically station and offset a point that is not on the alignment line?
For instance, our alignment line is the centerline of the road.  I need a station and offset of the new right of way line points at different places in the drawing.  I want to use the alignment stationing to have it automatically create the station and offset at the point I choose.
Thanks.
Caryn
4 REPLIES 4
arcallupe
in reply to: mnyrac
I don't understand very well. Do you have a polyline next to the aligment as rigth of way? and do you want to put the station and offset for each polyline point?. Is it correct?
seattlesurvey
in reply to: mnyrac
Try Create Points > Alignments > Station/Offset; you'll then need to choose thealignment from which you're offsetting, then enter the station along the alignment and the offset distance.
HTH.
troma
in reply to: seattlesurvey
That option will create cogo points.  Is that what you want?
I thought you just wanted a simple label of the station & offset.  If so, go to Annotate > Add Labels >
Feature: Alignment
Label type: Station Offset - Fixed Point
These labels display the station & offset from the alignment and will dynamically update if the alignment is edited or the label is moved.
Mark Green
Working on Civil 3D in Canada
mnyrac
in reply to: troma
I found the answer.
Select the alignment - in the Alignment Tab select Add Labels - Station and offset.
Thanks.
Rail Community
