Civil 3D Forum
Add Multiple Vertices
2 REPLIES 2
AKSBrettHartley
1561 Views, 2 Replies
I am trying to figure out how to had multiple vertices to a feature line.  I'm thinking its right in front of me, but I'm just not seeing it.  I have been adding vertices by "insert elevation point" manually and it is a really nice feature in that it picks up the elevation that is already attributed to the feature line, but it would be nice to speed up the process.
Thanks for any help.
Rand Waltz
2 REPLIES 2
You could use the Insert PVI method with the Increment option. Not sure if the Insert Elevation Point has an Increment option or not (not in front of C3D at the moment).
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Fantastic!  The insert elevation point has the same option toggle; it worked perfectly.  I new it had to be there somewhere; thank you for pointing me in the right direction.
Thanks again Brian!
Rand Waltz
Rail Community
