AutoCAD Civil 3D General Discussion
Member
tomhoban
Message 1 of 5 (438 Views)
Accepted Solution
Add Data to surface options Civil 3D 2014
438 Views, 4 Replies
10-30-2013 11:40 AM
Hello all
I am learning to use surfaces in drawing, My main aim is for volumisation tasks.
I had been following a tutorial that relied on creting surfaces. i.e
1) from the home tab> Surfaces> Create Surface
2)Add data. From Modify Tab>Surface> Add Data> Point Files.
This worked for me to start with but after changing some settings (looking to display a missing toolbar, I clicked or unticked one  or two boxes, Not sure where, I know silly!). The only options I have in the drop down from "add data" are: Boundaries and DEM files. All other options in the list are not clickable.
Can anyone help with this? ie What setting I need to change or perhaps restore all settings to default. Any comments on volumisation (spoil heps, Data is x,y,Z from survey equipment.
Thanks in advance for any help.
Regards
Tom
Active Contributor
wetsnow13
Message 2 of 5 (384 Views)
Re: Add Data to surface options Civil 3D 2014
10-31-2013 08:31 AM in reply to: tomhoban
Right click the surface name in the prospector tree, select the "surface properties", go to the Definition tab and open up "Data Operations".  Toggle all of them to "Yes"
Member
tomhoban
Message 3 of 5 (353 Views)
11-02-2013 02:07 PM in reply to: tomhoban
Thank you
I carried out as suggested but the options are still not selectable. However if I expand "definition" in the prospector tree and right click point files, I do get and option to add points and this works.
Regards
Tom
*Expert Elite*
Jay_B
Message 4 of 5 (346 Views)
11-02-2013 02:23 PM in reply to: tomhoban
Sounds like you may have changed the CUI settings.
These can be Restored or Reset as described in This Thecadgeek post.
Reset will as it states reset CUI to the original default settings so any CUI customization will be lost.
Jay
C3D 2014 SP2
Win 7 Professional 64 Bit
Member
tomhoban
Message 5 of 5 (332 Views)
11-03-2013 02:28 AM in reply to: tomhoban
Thank you. This worked
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
