Hi everyone.
I am just not very professional with C3D.What i want to do is ; i have a corridor with both right/left sides ending with linktosurface with fixed slope.In some sections my exisiting surface is not wide enough to get intersection with linktosurface with fixed slope.So i want to use this "conditional horizont target " if my surface is not enough wide for intersection then just intersect or go to the edge of my existing surface.But i learned that surfaces cannot be used as an offset target with that subassembly. I wish i could explain it.
Thanks for your helps.
But i learned that surfaces cannot be used as an offset target with that subassembly...
That's correct....
Try using the DaylightInsideROW for this design scenario instead:
Extract your EG surface boundary and use it for the ROW Offset target. Set the Hold Slope input parameter to Overide Maximum Slope.
This will allow your typical daylight slopes to be realized along the Corridor, unless there is not enough lateral extent on the EG surface to accomodate them. In that case, the daylight link will be pinned to the ROW offset target at whatever slope is required.
In the Help for this subassembly, see Logical Case #3 to see how this works.
Thank you for you help...I think this daylightinsiderow is what i need.But as you see in that photo when i apply this to my assembly the fill slope goes reverse direction.Am i misssing a point?
You need to extract your EG surface border and use it for the the horizontal ROW Offset target.
Try offsetting that extracted border line a little bit to the inside of the surface boundary.
Maybe it is having trouble picking it up exactly on the surface border boundary.
Maybe this is not going to work. Maybe it fails on the first try when it can't find the Daylight surface at the typical slope. That would not be very rigorous programming if that's the case.
Manual solution:
You could break up that surface boundary and use it for a Conditional Horizontal Target for the areas you know do not have enough lateral extent of topo coverage, and attach a DaylightToOffset subassembly if the Target is Found..
The boundary target enclosed the Corridor in a rectangle. When I broke the polyline target in order to have the polyline on just the right side of the target, the subassmbly behaved normally.
It looks like you have enough surface coverage to daylight at 4:1 though...you're not short?
Hello... Sorry for the late answer.Yes my EG is enough for 4:1 fill slope..Actually this is a tutorial for me and i often face this situation in other projects So i need to solve this.just...Assume that the typical fill slope is 60:1 . I tried even by breaking the target but no succes yet..I want my daylight to target the boundary of my daylight both horizontal and vertical if it can't target my EG with 60:1 fill slope.
umit
Yes, you're right. The Overide Maximum Slope option is not working. It is not pinning the daylight slope down to the Target surface at ROW Offset Target.
I offsetted a polyline 0.1' inside the Target surface border to be used as the ROW Offset target, just to be safe.
I will submit this as a Suport Case.
