Civil 3D Forum
ANZ Country Kit for C3D 2015
6 REPLIES 6
STACEROGERS1301
1257 Views, 6 Replies
Will an ANZ Country kit be provided for C3D 2015? If so, when?
6 REPLIES 6
Jeff_M
in reply to: STACEROGERS1301
It is available when installing C3D2015.
Jeff_M, also a frequent Swamper
STACEROGERS1301
in reply to: Jeff_M
I just installed the entire Infrastructure suite of 2015 and did not see any prompt for country kits. Did I miss a step?
Jeff_M
At the screen showing which programs to install there was a down arrow below the Civil C3 2015 option, this expands to where you can select the different options, including the Country Kits. You can still install it by going to Control Panel, Uninstall a program, select C3D2015. It will come up with a screen to select Add/Remove Features, Repair/Reinstall, or Uninstall. Choose the Add/Remove Features option.
STACEROGERS1301
in reply to: Jeff_M
Thanks for your help. Unfortunately when I select the add/remove features button, nothing happens. Worse still I cannot close/exit the window except by ending task in task manager.
Jeff_M
Looks like the Suite version takes a while to determine what can be updated. Have patience...it took nearly 5 minutes from the time I chose Add or Remove Content for the list to display. During this time I was unable to get any other button to function.
jimmygd
in reply to: Jeff_M
I just installed the UKIE country kit and now my US Imperial and US Metric kits have gone away. Where are the US Imperial and Metric .xml files located so that I can get those shortcuts back on my desktop?
Rail Community
