AECOBJEXPLODE appears to be broken. I have been fighting this for months and just now put two and two together. It appears to be a Civil 3D 2013 problem.
The Issue
I have a Civil 3D surface I need to explode so I can send contours to a client.
Here the Civil 3D Surface reports the correct elevations
This is the surface elevation after I used AECOBJEXPLODE. The units of the drawing have been changed to “Architectural” as well.
This the same surface if I simply explode it twice. The contours are correct.
Has anyone seen this before, and is ther a fix for it, i have been able to replicate this on many PC and it seems to be limited to Imperial units.
Cheers
Paul
If you just need pline contours the Exact Objects command form the contextual surface ribbon tab will not produce the error.
John Mayo
