Civil 3D Forum
AECOBJECTEXPLODE changing elevations
2 REPLIES 2
theminiguy
327 Views, 2 Replies
AECOBJEXPLODE appears to be broken.  I have been fighting this for months and just now put two and two together. It appears to be a Civil 3D 2013 problem.
The Issue
I have a Civil 3D surface I need to explode so I can send contours to a client.  image002.png
Here the Civil 3D Surface reports the correct elevations
This is the surface elevation after I used AECOBJEXPLODE.  The units of the drawing have been changed to “Architectural” as well.
This the same surface if I simply explode it twice.  The contours are correct.
Has anyone seen this before, and is ther a fix for it, i have been able to replicate this on many PC and it seems to be limited to Imperial units.
Cheers
Paul
~~Laptop~~
Quad Core 2.3GHz Intel, 64-Bit, Win 7
16GB Ram, 2GB Graphics Card
256GB SSD
~~AU2009 Speaker~~
CV314-5: AutoCAD® Civil 3D® Design Straight Out of the Box: Going Where the Design Wizards Can't Always Go .....
2 REPLIES 2
rkmcswain
in reply to: theminiguy
Using C3D2013SP2 here, and I cannot duplicate this behavior. Just curious, if you run the command AECDWGUNITSSETUP, is the "Drawing Units" set to Feet? I changed mine to various settings and still does not change the elevation of an "exploded" contour line. Not sure what else it might be. Do you have a small sample drawing with a surface you can upload for testing here?
R.K. McSwain     | CADpanacea | on twitter
jmayo-EE
If you just need pline contours the Exact Objects command form the contextual surface ribbon tab will not produce the error.
John Mayo
Rail Community
