I'm in process of cleaning up an inherited drawing and I keep getting the following recurring 4 errors every time I audit or run a recovery. When I look through the recovery log I see the following note: "AECC Db Class Node 31C4 error". At the end of the recovery log it states the four errors are repaired -- but next time I audit there they are. Any ideas how to fid the drawing of this problem?
experiencing the same issue with a drawing I started to use that was already created.
Let me know if you figured out a way to solve it.
I looked through my prospector and tried what you guys described above and still no luck.
I am big on auditing a drawing for errors and all it does it show the same 4 every time almost like it tries to fix them in the audit but then the errors regenerate.
Maybe gonna try a recover drawing and see what happens.
