Solved by AlmasSuljevic. Go to Solution.
Same issues here. Sorta. One computer shows the AECC_CONTOURS correct, another does not.
The command "DISPLAYMANAGER" on the incorrect system does not have the "Civil Contour Object", or the other "Civil" objects listed, where on the good system it does.
Have done the uninstall, and reinstall procedure which did not produce a positive result (except to the time card).
Hi all,
This may be caused by AeccCivilBase.dbx not loading. You can try loading it this way and see if that would be helpful:
1. In command line type APPLOAD
2. Browse to C:\Program Files\Autodesk\AutoCAD Civil 3D 2010\ and select AecCivilBase.dbx
3. Click Load and Close
4. Reopen your drawing
Hi rriley-
Try opening a Land Desktop tutorial drawing, then opening the drawing that doesn't show the contours correctly in the same session of Civil 3D. The contours should appear as expected now.
Hope this helps!
I haven't seen this problem myself. But I was wondering if you use QuickSelect to select the AECC_Contours do you find any. If QuickSelect finds and selects them I'd try Hiding and then End Object Isolation. Something in the back of my mind says that could work.
Allen
Allen Jessup
Engineering Specialist / CAD Manager
Hi everyone,
Please use Almas' suggestion to work around this problem for now. We have logged this as defect 1331756.
