Civil 3D Forum
ADD A TURN OUT ALONG A BIKE PATH CORRIDOR
4 REPLIES 4
849 Views, 4 Replies
I need to add a turnout (not intersection) along a bike path at a given station (see pdf attachment)
if I draw a turnout with nice arcs and lines, is there a way to add it to the corridor with extended
cross slope from the assembly at that point?
John Wilson
4 REPLIES 4
yes, it's possible.
You have to use a BasicLaneTransition.
Please use help for better explainance.
Good luck.
Thank you very much. It helped to research edit target to a polyline layout
John
Neilw_05
While polylines can be used as targets they are static entities, so they don't move if your alignment changes. A better solution is to use offset alignments with widenings. Then you can move the widening along the baseline or edit it parametrically. You want a solution that is dynamic to changes to the design.
Also for a widening you should consider using an offset in your assembly so that your template will be perpendicular to the edge of pavement through the widening.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
in reply to: Neilw_05
Thanks Neil
I'll look imto that
John
Rail Community
