AutoCAD Civil 3D General
Active Contributor
Message 1 of 5 (286 Views)
Accepted Solution
ADD A TURN OUT ALONG A BIKE PATH CORRIDOR
286 Views, 4 Replies
10-29-2012 12:29 PM
I need to add a turnout (not intersection) along a bike path at a given station (see pdf attachment)
if I draw a turnout with nice arcs and lines, is there a way to add it to the corridor with extended
cross slope from the assembly at that point?
John Wilson
Valued Contributor
bpoleuca
Message 2 of 5 (283 Views)
Re: ADD A TURN OUT ALONG A BIKE PATH CORRIDOR
10-29-2012 12:55 PM in reply to: johnwilson0805
yes, it's possible.
You have to use a BasicLaneTransition.
Please use help for better explainance.
Good luck.
Active Contributor
Message 3 of 5 (258 Views)
10-29-2012 04:48 PM in reply to: bpoleuca
Thank you very much. It helped to research edit target to a polyline layout
John
*Expert Elite*
Neilw
Message 4 of 5 (246 Views)
10-29-2012 11:45 PM in reply to: johnwilson0805
While polylines can be used as targets they are static entities, so they don't move if your alignment changes. A better solution is to use offset alignments with widenings. Then you can move the widening along the baseline or edit it parametrically. You want a solution that is dynamic to changes to the design.
Also for a widening you should consider using an offset in your assembly so that your template will be perpendicular to the edge of pavement through the widening.
Neil Wilson (a.k.a. neilw)
Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
WIN 7 64 PRO
HP Pavillion h8xt, i7 2600, 12 GB
RADEON 6450, 1 GB
http://www.sec-landmgt.com
Active Contributor
Message 5 of 5 (187 Views)
10-31-2012 06:47 AM in reply to: Neilw
Thanks Neil
I'll look imto that
John
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
