I've created high resolution surfaces for ADA ramps via 3D feature lines
dynamic slope labels work great
what is the best way to get dynamic point elevation info? The idea is to display curb ramp points for contractor stake out and setting forms
I've manually created points by snap to the feature line, then a point table works, except if the feature line is modified the point table doesn't update
other ways to get curb ramp point elevations that auto update?
thx,
Solved by AllenJessup. Go to Solution.
Solved by jeff_rivers. Go to Solution.
Solved by BrianHailey. Go to Solution.
Solved by Mark_Castle. Go to Solution.
Solved by wfberry. Go to Solution.
Solved by Jeff_M. Go to Solution.
Solved by jblackwood. Go to Solution.
In a table? Not that I know of.
In the model? Sure, just add surface Spot Elevation labels.
If it has to be in a table, the only thing I can think of is points but they don't automatically update when the surface changes. It's easy enough to update them (and then the table automatically updates) but you have to remember to do it.
I was hoping we could trick a line/curve table into allowing it but the line/curve table won't display the start or end segment elevation.
The best option that I can think of is to use Spot Elevation annotations with a little twist.
1. Create a new spot elevation label style that shows x,y, and z values. Make sure that the dragged state does not show a leader.
2. Create a table by hand using lines and text for header. Create a block if you have a lot of tables to create or for future use.
3. Annotate the points using the new label style.
4. Drag the annotation to the table.
This way the z values will automatically adjust when the surface is updated. The hardest part will be adjusting the spacing between x, y, and z values so that everything lines up the way you want them to.
If you are using Station/Offsets instead of x and y or northing/eastings I would use reference text that references the alignment to get station/offset/offset side values.
Sincpac C3D's Dynamicaly Linked Points would work well for this.
Labelling the feature line seems to me to be the more dynamic method.
Bill
We've placed pipe structures at the points at then created a structure table. This works pretty well and updates when the surface is modified.
Great idea but, creating a table by hand with plines and text? Nah, use the AutoCAD table command!
These are some great answers! In my plans I've used the labels set to 'no leaders' in dragmode, and just dragged them out to be just adjacent to the relevant feature. I like the structures + structure tables answer.
In the bigger picture we have generally found that there is little benefit to providing elevations for any parts of the ADA ramp. We provide elevation tables for the proposed flowline, then provide the ramp grades only for the remaining ramp features (except we also do provide elevation points at the left and right sides of the ramp at the flowline). We do this becase we've found over several projects that the actual as-constructed curb line elevations may vary from the as-designed curb line elevations. And if the flowline has changed then every plan elevation for that quadrant is wrong and must be recalculated.
We provide the contractor with as-designed grades only, no elevations beyond the flowline. We want the contractor to hold to the ADA compliant design grades. We do not want the contractor to build to any plan elevations because if there is any change, those elevations now may or may not provide a compliant grade.
I would be very curious to learn what others are doing: How much information they provide on their ADA curb ramp plans and any problems they've encountered in the field specifically from showing too much or too little information on those plans.
Honestly. All we show is the position and flow line grade plus the standard state DOT detail. The contractors build from that. I should mention that there is usually stakeout by the contractors Surveyor with grades based on the flow line.
I've been on the other side of things. Doing the staking. Back then all we usually had from the plans were a grade at the center of pavement and a typical section. The rest we calculated from those.
I'm not saying that more information isn't better. But the Contractors and their Surveyors are usually competent plus we have inspectors on the jobs to check them.
Allen
Allen Jessup
CAD Manager - Designer
@jblackwood1 wrote:
Lately the government agencies we do work for have been asking for more and more detail
You need to satisfy the agency that has to approve the plan. However I usually find that this method of "solving" a problem rarely works. If a contractor can't build a compliant ramp from standard specs. More information will either confuse them of they'll ignore it and still find an excuse.
I work for a County Highway Dept. and if one of our inspectors found that a contractor had put in a non-compliant ramp. The contractor would be tearing it out and putting it in right. The type of more information approach tells me that they're unwilling to confront the real problem and are reverting to CYA. You need to consider a contractors ability to construct the project above the bid price.
There's no problem in using Featurelines or 3D polylines for design. I have draw ramps in 3D in the past. I'm currently using Featurelines to target the bottom and back of the ramps. I just don't publish the information once I know it will work.
Allen Jessup
We do exactly that: create automatic proposed surface elevation tables using structures.
You have many many solutions here is one that WILL giveyou a dynamic point table.
dont use points. You already have this high resolution surface, so where you would place points place pipe network structures style to look accordingly and use a structure table also styled accordingly.
Your Name
Your Name
